[QLD] Need help! Lowering front suspension, please identify this part!
Burto89
Gladstone QLD
2004 VZ S-Pack Ute
Hey guys,
Well lowered the rear of the ute yesterday was a great success but today with the fronts i am little lost! Below is a picture of a part that im not sure if i should replace, grease, use as is or what. Anyone who has any ideas or pointers I would be most grateful!
Pics:
Is it a dry bearing? and should there be more ball bearing in the rung????
Burto89
Gladstone QLD
2004 VZ S-Pack Ute
Cheers ozzypole! So in the link there, it has the bearing inside the yellow ring I assume? And no to be honest there was no noise and even turning the strut mount now its quite but I was just like that cant be right!
Adds_05
Central Coast, NSW
VT SS 5.7L
the tops and the bearings are stuffed, in the second pic of the rubber strut top,see how its split around the metal ring in the middle,you will keep chewing out bearings if you dont replace that.
as for the bearings,theres a white and a yellow part that are together which holds the bearings in,that has come apart,more than likely due to the tops being stuffed
Burto89
Gladstone QLD
2004 VZ S-Pack Ute
Hey cheers everyone for the info! Will buy new bearings and strut tops on monday, thats if holden is not crazy expensive like usual!
thekid93
brisbane
vt s pack
lol dont go to holden. there about 80 for the top plus bearings another 40...
superpro for 180!!
Burto89
Gladstone QLD
2004 VZ S-Pack Ute
Yea kid, thats all very well but I need my car back asap so if i can get them from Holden first thing monday i will otherwise I will order a set.
