Need help of installing gps antenna on non-sat nav vf commodore
mz2017
SA
VFii Commodore SV6
Hi everyone, I'm upgrading my non-gps vf2 sv6 with factory gps head unit, thanks to @Tasmaniak for his fantastic post otherwise I have no clue of how to dissemble these things... anyway long story short after the magic moment when I plugged the flash box (sourced from ebay) to obd2 port and the head unit unlocks in literally 3 seconds, here comes the frustrating part, there's no gps signal due to aerial issue...
but I want the factory aerial like this:
now there're couple of questions messing around:
1.
the seller suggests me some aftermarket gps module like this:
but I don't know how to set up... the wire interface of the head unit is exactly the same with my old one and I figured out one of the plugs may be the the one that receives gps signal, but it's currently used for AM/FM, which means if I plug the gps instead, the radio is gone, other than that I doubt the gps signal might be affected as well because the only way I can think of to fit it in is to squeeze everything into the head unit housing under dashboard:
and I'm curious how does the aftermarket integrated gps system works, do they also put gps antenna behind the grey box head unit and push it in?
http://www.naviplus.com.au/holden-mylink-gps-navigation-upgrade
2.
I searched for factory antenna and spot the clear difference:
so the gps antenna has a larger base and two plugs, while non-gps antenna only has one. However I have no idea how to swap it, there're no external screws or whatever, maybe I need to remove the lining from inside first...
mz2017
SA
VFii Commodore SV6
for anyone who's interested of head removal and unlock there're some extra pics,
my non-gps unit and gps unit, same look but gps unit has an extra socket
the annoying plug mentioned by @Tasmaniak , need to flip the buckle first and pull out
the screen shows locked after swapping
the flash box, works like magic
I bought it here:
https://www.ebay.com.au/itm/VF-SERI...232713?hash=item466ae6f949:g:JSgAAOSwHhRa4iC8
you need to send it back after use to get back deposit though
system unlocks... unfortunately no gps signal
dgp
VF II SSV Redline
To replace the antenna, you need to remove the headlining.
IMG_1081.PNG IMG_1082.PNG IMG_1083.PNG IMG_1084.PNG IMG_1085.PNG IMG_1086.PNG IMG_1087.PNG
dgp
VF II SSV Redline
Remaining pics of procedure
IMG_1088.PNG IMG_1089.PNG IMG_1090.PNG IMG_1091.PNG IMG_1092.PNG IMG_1093.PNG
mz2017
SA
VFii Commodore SV6
Thank you very much dgp, unfortunately I have to give up factory whip aerial because I only found today that the sockets of head units are actually different... big mistake! There's a dedicated port for gps signal which I didn't notice, so an extra cable needs to be added to the cable bus to suit factory aerial.
I'm searching youtube for aftermarket antenna installing and there're plenty of them, usually glued under dash board. Of course the signal will not be as good as putting on the car roof but I'll see.
non-sat nav head unit
sat nav head unit, blue port for gps
Mavericks Choice
NSW
VF2 SSV M6, VF2 LS3 Calais V, VZ 6L M6 Crewie
Have fitted other A/M GPS units to various cars, you won't lose much signal by fitting the GPS antenna under the dash.
Skylarking
123
Downunder
Commodore Motorsport Edition
If you did decide to go with the standard GPS antenna and thus remove the headlining, that would be the ideal time to also do the electriochromatic mirror and sunshade lamp upgrade and why not add front and rear chresh cams :) Go the whole hog, no expense spared :cool:
joban
30
new Zealand
holden commodore sv6 2015
I bought it here:
