Need help! Ve battery dead can't open doors to access
Jackster101
33
Forest Glen Qld Australia 4556
Holden omega 2007 ve utility v6
Hey guys n gals,
I'm experiencing an issue where I have left my 2007 ve ute in the garage for over a month all locked up and now that I've decided to take it for a drive... Noticed when I went to unlock it with the button nothing happened so I thought il change the key battery but no difference....i tried using the key in the door and nothing. Decided I'd put my hand through the grille (mind you I have a letterbox grille) and accessed the cable and opened the bonnet... Thought I'd had success I connected a battery charger to the positive terminal in the engine bay and a solid earth point but all that did was set my alarm off! Now when I look through the window I can see a lock symbol on my dash. I need to some how disconnect the immobiliser but I have no idea how!
Can anyone please help this is very frustrating and I need it for work ASAP
Jackster101
33
Also tried connecting to the alternator and a solid earth. It gave me more power and I could see the dash light up but still had the immobiliser light pop up. Even after disconnecting the charger and closing the bonnet it wouldn't disappear
Immortality
Staff member
Sth Auck, NZ
Hi and welcome to the forum.
As per the forum rules we only allow one thread per topic.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Even if the key battery and main battery are flat, the key should unlock the door.
When the door is unlocked, put key in ignition and turn one click(Should disable the alarm).
Charge(or change) the battery...
Jackster101
33
Hey mate I just tried it again. Nothing it won't budge. Someone said something about lifting the car up and attaching a charger or battery to the starter motor to give enough power to unlock the doors.
lmoengnr
Donating Member
Sunbury Vic.
The door key lock has a rod directly to the door lock actuator to override the door lock.
Fully insert the key in the lock and turn clockwise, it may take a bit of force to unlock, if it hasn't been done for awhile.
Jackster101
33
Thanks so much. I used a serious amount of force but could feel the rod move and the key slowly turned. I feel so stupid but so thankful man cheers
h8tensv6
Newcastle NSW
2009 SV6 2002 VX 1989 VN 5 Litre
This is common on cars that haven't had the key lock used for many years. I had the same problem with my vx. I almost snapped my key off trying to get mine open.
vr304
Auckland, New Zealand
2007 ssv manual
Perhaps spraying some crc into the lock will help free it up
