need help with a 5liter conversion into a vl
*uwishn*
Holden special vehicles
sydney
vl walkinshaw(replica)nissan navara d40 st-x turbo
what do i need to put a 5 liter in?? will my manual v6 box bolt up to it with a custom bell-housing or is that a no no!!??
ecu,fuel pump,and the engine to be wired up.
will the cross-member,tail shaft, be all good?
really need some one who has done it any help would be apreciated,cheers.
nasty1
adelaide
vy2 clubsport
ive done this.
you need a v8 k frame.
the t5 crossmember fits you just have to re drill the mounting holes on xmember
tail shaft will be t5 front half bolted to vl rear half
you need vb-vl v8 pedals vn and vl pedals dont fit[i have vh v8 manual pedals you can buy]
*uwishn*
sydney
cheers mate what can you do the pedals for??
also i found this info is this basicly every thing to know??
To convert a vl 3litre to 304 v8
*vl or vn v8 k frame needed
*vl or vn v8 gear box cross member needed
*vl non power steering rack or a vn v8 power steering rack(to make the headers fit in and for ample starter motor clearance)
*vl-vs v8 radiator needed
*vn v8 accelerator cable needed
*custom the tail shaft you’re self-front half vn v8-rear half vl v8 or turbo only.
*vb-vl v8 pedals needed
Auto electrician will charge roughly $400 to wire the engine up
Vl disc brake rear end will be ok as well as the master cylinder and front brakes,
The fuel pump will also be fine because the car is already injected.
If going automatic you will need to bash the tunnel abit depending on what box you go with.
nasty1
adelaide
vy2 clubsport
yeah your on the ball there mate with that info its an easy task to
$80+postage only cause they are hard as to find.
evan wiring it your self is only a handfull of wires but $400 is good
you can buy looms already made to suit also
*uwishn*
sydney
hi mate so does the vl have the t5 box or mx5?
if it has the t5 ive been told you need to cut the shaft and get a custom bell housing is that correct how did you go about it?
do you know where i could score one of the looms
thanks for you're help mate ill contact you next week about them pedals cheers.
nasty1
adelaide
vy2 clubsport
t5 box
no cutting of anything mate the t5 stays mounted to the 304 then you use vn front half of tail shaft and vl rear half trust me i have done it.
dont listen to people who sey i hurd this from my cousins mums boyfreinds,auntys,nonos and habbib said so lol
Untitled Document for that loom
nasty1
adelaide
vy2 clubsport
click that link mate up above its called untitled link.
good luck its an easy conversion just a bit of head #### changing k frames but you can have the rb30 out and 304 in a weekend
*uwishn*
sydney
cheers mate appreciated.
nasty1
adelaide
vy2 clubsport
also the hsv headers fit in nice just watch out what extractors you buy
