Need help with lifters problem
Discussion in 'VE Holden Commodore (2006 - 2013)' started by almuhands, Apr 12, 2014.
  1. almuhands
    almuhands New Member
    Saudi
    Lumina 2007 V6 3.6l
    hi there
    my Car is Chevy Caprice 2007 LS with 3.6L - V6
    Mealge is 110000 KM ( about 65000 mile )
    I have noisy lifters sound since 1 year
    I've tried flashing Oil but and different types of oil but no difference the sound still the same
    dealer says , I should change Oil pump and open engine head to change lifters but that cost XXXX$ !
    How I know the problem is from Oil pump or Lifters ??
    plz check my video to hear the sound
    http://www.youtube.com/watch?v=LeKKi8zsuEI
    [YOUTUBE]Chevrolet caprice - holden lifters knocking - YouTube[/YOUTUBE]
    thanks
  2. NU13
    NU13 Well-Known Member
    New Zealand
    2007 E1 HSV GTS Manual
    Run it at high rev's for about 20 to 30 seconds. See if that improves the noise any.
  3. almuhands
    Saudi
    Lumina 2007 V6 3.6l
    higher rev's make the noisy faster bit the same level
    the sound in the video on youtube the more than actual sound
    I think it's as you make the sound As 50% on youtube
    Does Pcv valve can make a noisy ?
    where is this valve
    thansk
  4. Rambodian
    Rambodian New Member
    NSW
    VZ Executive
    You could try that seafoam stuff
  5. Big-Al
    Big-Al Banned
    Aussie and proud
    VY SS 5.7 M6
    ah well you know the issue is the lifters or the oil pump so don't be cheap and get them replaced. Otherwise turn the stereo up, there is no magic bottle of additive that will make it go away.
  6. someguy360
    someguy360 Well-Known Member
    Adelaide Hills
    If there is an issue with the oil pump I would be replacing it sooner rather than later, if the oil pumps causing it, it means you aren't getting desired oil pressure and the engine will not be lubricated properly leading to early engine wear/failure. (in fact if it was my car and I determined the fault to be with the pump I wouldn't be driving the car at all until it's fixed)
    If it's just a lifter it could go another 200,000km with ease.
  7. almuhands
    Saudi
    Lumina 2007 V6 3.6l
    there's no Oil caution light
    but I can't check the sound because of lifters or Oil Pump
    changing oil pump is expensive and if it's not the real problem that's a bad situation losing money and problem is there !
    thanks
