Need Help
Discussion in 'General' started by GothicKidd, Jul 12, 2011.
  1. GothicKidd
    GothicKidd ლ(ಠ益ಠლ
    South Australia
    VR S2 Exec
    What should I do?
    Two bolts holding the waterpump, snapped.. One reachable and the other being unreachable (about 2cms or so inside)..
    I was thinking of maybe taking off the timing cover but one of the bolts wont undo and started stripping at the head..-Any tips on removing stubborn bolts? /any howtos to remove timing cover?
    I feel like giving up. :\
  2. sweefu
    sweefu New Member
    VY Berlina V6 / R31 Skyline
    Is this on a buick v6?
  3. GothicKidd
    GothicKidd ლ(ಠ益ಠლ
    South Australia
    VR S2 Exec
    Ah sorry.. Forgot to mention.. Its a 253cui engine
  4. ben315vz
    ben315vz Donating Member
    Tamborine Mountain, QLD
    '05 Holden VZ Calais V8
    Thats happened heaps of times at work. There is these tools you can buy called "easy outs". What you do is drill a hole into the broken/snapped bolt, then get the easy out and lightly tap it into the hole in the bolt you just drilled. Then get a shifter and turn it anti clockwise and it should come out.
  5. GothicKidd
    GothicKidd ლ(ಠ益ಠლ
    South Australia
    VR S2 Exec
    Ooooh thanks :D Would I be able to find them at either Repco, Supercheapauto... or auto pro?
  6. ben315vz
    Not sure exactly where they bought them from but they usually buy there tools from Repco, and if Repco doesn't have them, Bursons is usually their second option.
