Corey
Okay so today I was driving doing 100km/ph and my car shut off. When I pulled over it clicked for a couple of seconds so I tried again and it turned over straight away. Because I was pretty close to home I decided to keep driving and it would rev up and down as I tried speeding up and even cut out again at one stage but then started back up:hmmm:. So with a bit of research I found CAS was a likely problem BUT I did a code check and got error code 76: Code 76 - Air/Fuel ratio variation between left and right banks. Researching that all the problems were different than the CAS
So my question is, what is the mostly likely scenario that's wrong with my car :bang: that could make it cut out and give me error code 76? Thanks in advance
