need help
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by peter72, Nov 1, 2008.
  1. peter72
    peter72 New Member
    vt11 5.7
    I just had the exhust done on my car. Extractors and a 2 and a half exhust installed been going well. Now all of a sudden all my waring lights come on ... trac off , power train , airbag , abs ,whats going on ??? They come on for about 5 min then turn off then come on again about 15 min later. i put a high flow air cleaner in it aswell never had a prob with the car till i made these mods can any one please help....
  2. Ozzie
    Ozzie JCCC Warrnambool
    Warrnambool
    Ozzie'z Supercharged VY Calais
    what did you do with the air temp sensor and the air flow sensor when you installed the hi-flo CAI?
    can you post a pic of the air cleaner setup for us
  3. peter72
    peter72 New Member
    vt11 5.7
    what do you mean ?
  4. lumina01
    lumina01 New Member
    Melb
    MY10 SSV UTE
    i think he just added a new air filter not cai...
  5. Ozzie
    Warrnambool
    were there sensors on the standard air cleaner and did you remove them?
    ahh ok. did he remove any of the sensors? make sure their still plugged in
  6. peter72
    peter72 New Member
    vt11 5.7
    all i did is unsrewed the intake lid replaced the air filter with a k&s filter then screwed the lid back on
  7. peter72
    peter72 New Member
    vt11 5.7
    there all still pluged in
  8. Ozzie
    Warrnambool
    take another look at the air box... there should be a small black sensor on the side of it. Check that it is plugged in correctly.
    Also check all connections arrount the extractors to make sure he hasnt bumped any wire connections
  9. peter72
    peter72 New Member
    vt11 5.7
    i'll have a look at it and see what i can find might take the car back to the machanic and get him to look at it again
  10. peter72
    peter72 New Member
    vt11 5.7
    although dont know if i should trust him when he fitted the extractos he fergot to tighten my steering rack up what a tool
  11. Ozzie
    Warrnambool
    yep judging by those symptoms (car still starts) itd be a sensor playing up
  12. Ozzie
    Warrnambool
    maybe hes doing it deliberatly to get you back there ? = $$$$
  13. Ozzie
    Warrnambool
    as far as i can remember theres also a sensor on the standard headers. maybe when he installed the extractors he left it out
  14. peter72
    peter72 New Member
    vt11 5.7
    i just had a look and all the wireing is all conected cant see te sensors on the extracters there under the car
  15. peter72
    peter72 New Member
    vt11 5.7
    i just disconested the battery for half an hour and it started alright and the warning lights wernt on what but whos to say they wont come on again tomorrow
  16. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    This is usually a sign that there is a problem with the ABS module. It happens a lot. Do a search and you will find lots of posts about it. Does the oil light come on as well?
