Need Some Help
gregfest
34
nuriootpa
vx
I am looking for the location of the fuse or something for the wire that runs to the trailer plug for aux power on my vy wagon.
Went to plug van in but now have lost voltage from the aux power. Any help would be greatfull.
I have put a volt meter on and getting no reading.
wamboin23
Donating Member w/ Boost
34
Wamboin, NSW
VS Calais - Cooled L67 + T56 | VF SSV Ute
If it is just stock, you won't have power there, but it may be connected to reverse lights.
You will more than likely need to run a dedicated supply from the battery.
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
Factory wiring harness for the vy trailer plug attaches to the tail light loom on the rh side with a separate plug just for the lh indicator. You'll need to run a dedicated aux cable
Trevor loves holden.
vs commodore
Well if someone ran a wire for a Aux for power to run a 12v fridge then you blown a fuse if its no longer working, depends who fitted it as where the fuse is located, most probably near the battery or off a power fuse some where, you will have to just look at all locations to find the blown fuse. 7 wire plug doesn't have Aux wire just a reverse and service brakes.
