Need Urgent Help!!!
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by rabsy, Mar 2, 2007.
  1. rabsy
    rabsy New Member
    my vt commodore is over heating but the problem is the temp gauge is reading normal but because of this the fans arent coming on. The only way i can get the fans to come on is when the air conditioner is on. please send back immediately
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    What's it doing to make you think it's overheating?
  3. pr0n
    pr0n It's A Me ' MARIO '
    Gladstone
    03 VY II S V6
    if the temp guage is reading normal than it wont be overheating. also new motors run at way hotter tempretures than older engines.
  4. rabsy
    rabsy New Member
    water and radiator fluid is bubbling and smoke
    being brief
  5. 14secvp
    14secvp New Member
    south island newzealand
    vp v6 commodore executive
    blown headgasket maybe
  6. rabsy
    rabsy New Member
    mate thats the problem its reading the temp is normal but the car is over heating dude im not dumb i no when my car is overheating the fans arent turning on the cool it its not getting the message
  7. deano70
    deano70 New Member
    vx series II
    GEAR BOX VX SERIES ii
    Hi I cant work out how to open a new thread...can someone tell me I am registered...my gears are grinding from 1st to 2nd but it only does it sometimes... I cant work it out....NEED HELP
    14secvp likes this.
  8. rabsy
    rabsy New Member
    do u reckon there is something wrong with the thermostat
  9. WAGON MAN
    WAGON MAN Gas Sleeper
    North Coast , NSW
    VX S2 Berlina Wagon with Phreddied bits.
    It wouldn't hurt to change it.
  10. 14secvp
    14secvp New Member
    what do the bubbles smell like that are coming out. are they little bubbles or a real bad gurgling like youve cooked it bubbles thermostat could be jammed but wouldnt normally cause bubbles.
  11. 14secvp
    14secvp New Member
    deano70 you cant post a new thread if you are in a search goto the forum jump at the bottom of page pick your model from the dropdown list press go.the top of the next page on the left button says "new thread"at top of threads. like where it says " post reply" on this page at the top.
  12. rabsy
    rabsy New Member
    real bad bubbles man basically goin everywhere cant describe smell
  13. accentstencil
    Eschol Park, Sydney
    I can't say what your problem is but there are a lot of things that can cause overheating.
    1 Lack of coolant.
    2 Restricted flow in the radiator
    3 Thermostat
    4 Faulty water pump.
    5 Leaking cylinder head gasket.
    6 Faulty cooling fans.
    7 Slipping drive belt.
    8 Restricted exhaust system.
    9 Low engine oil.
    10 Dragging brakes.
    11 Slipping clutch.
    12 Engine tight after overhaul.
    13 Restricted airflow through the radiator.
  14. 14secvp
    14secvp New Member
    If it smells fumy its ya gasket like if it hurts your nose if you have a good sniff.any moisture coming out the exhaust.all the bubbles sort of say head gasket to me do you get more bubbles when you rev it if the gaskets to bad it will nearly pump the water out the filler in fornt of you when you rev it.
  15. accentstencil
    Eschol Park, Sydney
    I'm inclined to think head gasket also. Especially if they are small bubbles. If the bubbles are large it's because it's boiling.
  16. 14secvp
    14secvp New Member
    hopefully just gasket could possibly be a cracked head maybe but probably not
  17. veclubby
    veclubby New Member
    South Perth, WA
    2007 VE Clubsport
    wat colour is ur oil? whiteish?
