Neutral safety switch
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by madgadget, Apr 11, 2011.
  1. madgadget
    madgadget New Member
    Hi all,
    I am helping a mate fit up VS V8 running gear into a EH. All is fine but we needed to fit a aftermarket gear shift sender so that the auto gear positions light up on the custom console as the stock selector sender is now gone.
    I have to fit in the safety switch set up and looking at the stock sender on the selector it has 4 wires. I am guessing that it is for both the park/neutral safety cut out and the reversing lights. Is this correct? Which wires are which?
    Have I got it all wrong and is there already a safety switch in the ECU, the aftermarket sender unit I am using has outputs to use a relay to do this but if it's already there then all good.
    Thanks
    MG
  2. madgadget
    would anybody have a wiring diagram for this?
  3. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    PM me your email address and I'll scan and send to you.
