Cheap6
- Jun 19, 2005
- 2,498
- 74
- 0
- VP Exec
I bought a new multimeter from there today so i wanted to see how much DCA i was getting only to realize i had blown the fuse by first connecting the pins then turning it on (NEVER DO THAT) so i still don't know if my DCA is under .70 or over.
If I read that correctly you tried to read the current from the battery and blew the fuse in the DMM. Maybe that's a clue. Most of those DMM's are rated to read 10A, maybe 15A max. so what was 'on' that was drawing more than that current? (That's a lot of current to be drawn without anything switched on.)
If you do need to measure a current greater than that which the DMM can handle, Jaycar (and others) sell shunts. You temporarily wire that in between the +ve wire that supplies the power to the fuse box and measure the voltage drop across it. (The shunt is a very low value calibrated resistance and the voltage drop is converted to a current flow using Ohm's law: V=IR or I=V/R.)
The current drawn with ignition off should be something like 150mA (=0.015A), maybe not even that much. It's basically just to keep the memory alive in the electronic modules and to run the anti-theft monitoring. With the ignition off, it shouldn't be anywhere near enough to blow the DMM fuse.
If it is more than that, the diagnosis starts with removing each fuse one by one until the current drain disappears. Then you know that's the circuit to look at.
