MiKExAUS
- Jul 13, 2011
- 296
- 13
- 18
- Location
- Sydney NSW
- VX SS A4 Series II
Hey legends,
I have just replaced a shotty wheel bearing on the front LHS which I believe has caused wear to my slide pins on the brake caliper due to the abnormal forces from the disc not running true.
Basically wondering if I should just buy a caliper rebuild kit with new slide pins (definitely wear marks on old ones) OR get a wrecked caliper as the slide pin bores may also be worn? There is a significant amount of lateral/ radial play amongst their slide pins and their associated bores both top and bottom. Just don't want to fork out for new slide pins then find that I need a new caliper.
Anyone had a similar experience?
Thanks in advance!
PS. for anyone who has replaced a bearing/hub assembly- did you just chuck the o ring? Seems it would do stuff all to water ingress due to recesses in the stub axle.
Thanks in advance!
