New extractors leaking?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VS-S, Jan 17, 2014.
  1. Wozza
    Wozza Well-Known Member
    VR_GS commodore
    Check the intake piping ect to the throttle body airbox, they might not have done it up tight...check the brake booster hose isnt loose and check for other items they may have removed to get to the extractors..
    hissing/whistles are normally air leak related....
  2. Nut Kracker
    Nut Kracker Donating Member
    Echuca Vic.
    VT SS 304ci (195i)
    Don't touch it.....Live with it until you see 'em on Monday.
    If you go mucking around with it, more than likely they won't want to touch it after you or someone else did.
  3. VS-S
    Yep I'm not touching it. I had a mate listen for it under the hood as I pushed the accelerator and he heard it.
    Sounds like it's coming from the passenger side.
  4. Drawnnite
    2000 Vs Ute
    they aren't stainless steel by any chance are they?
  5. VS-S
    Nah man just mild.
  6. adam10_1990
    adam10_1990 New Member
    Brisbane, Queensland
    VS Commodore S2 Ute Manual
    I get alot of hissing from my front end under the bonnet on the passenger side but thats just the amount of air the intake is sucking,
    I have a ss CAI so its quite loud and can be heard inside the car.
  7. VS-S
    Mine has the stock intake.
  8. jchantrey
    jchantrey New Member
    wollongong
    VE SV6
    Definitely take it back. Could be gunk left on the headers when they attached the new, could be loose bolts. Crappy gasket.
  9. corhijasna
    corhijasna Member
    Portland Victoria
    how did you go mate,did they fix her up today????
  10. VS-S
    Unfortunately I didn't get a chance to get down to the shop today. To busy organising my 21st. He wouldn't have time to work on it today, only to have a look at it.
  11. corhijasna
    corhijasna Member
    Portland Victoria
    hopefully tomorrow then-good luck,pain in the butt but I am sure they will fix in the end
  12. VS-S
    Can't tomorrow because I'm working. Haha it'll get done.
  13. corhijasna
    corhijasna Member
    Portland Victoria
    haha,eventually lol
  14. VS-S
    Yeah man, don't worry it'll get done! Hahaha I'll let you know once it is and what the problem was when it's fixed.
  15. corhijasna
    corhijasna Member
    Portland Victoria
    sounds good,i'm not worried lol
  16. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Extractors change the intake noise quite significantly, unless it's leaking down where the Y pipe mees the extractors, it won't be a hissing noise. If it's on the passenger side, then it's most likely intake noise, you will probably notice a bit of a hiss when the engine is turned off too.
    If it's a extractor leak at the head it will be more of a chuffing noise than a constant hiss.
  17. VS-S
    Ahhh okay, I still want to get it checked though.
  18. Drawnnite
    2000 Vs Ute
    yeah I only asked about if it was stainless because I was like "what is that noise"
    went back and he said "its just the sound it makes" could hear an air sound even inside the cabin.
    if it is just the air and sound of the extractors you do eventually get used to it.
    NAAF is right though. I keep thinking theres something wrong if I have the bonnet open, but its just the sound they make.
    could you just get a bit of soapy water and look for bubbles when its cold to see for leaks?
  19. Vs hsv manta
    Vs hsv manta Member
    Mackay
    Vs hsv manta
    Oops I didn't see there was another 3 pages on this thread lol
  20. VS-S
    Got it looked at today. Seems to be fine. Could just be because they're new.
    He'll check it in about 500km's.
