[QLD] New foglight / driving light restrictions
Discussion in 'General' started by Caity05, Oct 4, 2009.
  1. Holden or Nothin
    Holden or Nothin Banned
    VY Storm SII
    My fog's turn on aswell when i do this :p
    previous owner wasn't an electrician.
  2. SuperSixty6
    SuperSixty6 Alto Rullo
    Brisbane.
    Landcruiser TD
    Maybe a dumb question,
    But i assume there is a difference between "Fog" and "Driving" lights. I have noticed the "Fog" to have a Frosted like lense, Hence it scatters beam of light everywhere making it illegal.
    However, I noticed the Driving lights have a Clear Lense, Are they still illegal?
  3. GAMBLR
    GAMBLR More trouble than u think
    Whyalla (yawn), South Australia
    '04 VZ Calais LS1
    Simply, a 'Fog' light has a switch in the cabin to turn them on and off independant of the main light switch. They can be switched on provided at least the parkers are switched on. The type of light they produce is beneficial in poor conditions, such as rain or fog where usual headlights are not enough. But they have to be switched off when conditions clear.
    Driving lights do not have a factory switch, as they are hardwired into the highbeam circuit, and only illuminate when the highbeams are on.
    In essence, every Commodore with lights down the bottom are classed as Fog lights because of the switch near or on the headlight main switch.
    As for the type of light they produce, I'm not really sure...
  4. SSv_6ltr
    SSv_6ltr Bundy on Dudes.....
    Brisbane QLD
    VZ Storm
    I drive with them on at night because it give a more of a spread beam beside the car...Too many Roos on the side of the road.
    People complain alot, esp at night because alot of drivers adj the height and change the wattage, they should be the same as low beam wattage...55w
  5. Drewie
    Drewie Active Member
    East of Melbourne
    VX SS (Original owner).
    Not sure if QLD is having the same new rules as VIC, but the one about no 'U' turn over a solid centre line, in VIC it also states no overtaking as well, so it sort of becomes the same as a double line. See the VIC link below. Maybe QLD is going to be a litlle bit different.
    Or was the no overtaking on a solid single already in place in QLD.
    "Victorian road rules: U-turns and overtaking"
  6. TMM
    TMM OEM+
    VIC
    VY Berlina S2
    Everyone says that about people who 'show off' their lights, until they get blinded by a 1990 Honda Civic with a 8000k HID retrofit. This is why we have laws that say what you can and cannot do :p.
    It doesn't matter whether they are on a switch or not, the colour/type of the lens, or where they are mounted, it's the beam which determines if they are foglights or driving lights.
    Driving lights complement high beams. They are simply bright lights that throw light everywhere just like high beams do.
    Fog lights have a focused beam which is designed to only light up the road. This is beneficial in foggy conditions. If you shine more light on the fog itself it'll make your visibility worse.
    As far as i'm aware, the only true Commodore foglights are the projector ones (VY Senator, VZ Monaro). All the other models don't have a properly focused beam, BUT the low mounting position does make them somewhat useful in fog, but not nearly as good as a properly focused beam.
    Either way it's a big no-no to have them on in the daytime no matter what they are. Driving lights fall under the same rules as high beams and Fog lights can only be used when it's foggy. The only lights you are allowed to have on a daytime running lights (i.e. parkers), or low beam headlights.
  7. VS_Pete
    Workmate has seen many people south of Brisbane getting booked. Police have a blitz on.
  8. Rufus®
    Rufus® I Jizzed in my pants
    The Marsh, Vic
    VR S1 S Pack, VX S2 Acclaim Wagoon
    This is new in Vic too, up until now it has been the responsibility of the passenger (over the age of 16) to wear a seatbelt. Now the Driver will be fined.
