New gearbox issues
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by buzurk, Sep 19, 2007.
  1. buzurk
    buzurk Guest
    Hey well as ya might know i had to change out me gearbox, Getrag 5 Speed,
    All went in ok, Put the oil in car is runing sweet!
    however, its leaking Gearbox Oil. not sure where from but seems to be leaving a nice patch everytime i park
    Got under car and looks like its spraying a tad around the tranny tunnel, and seems to be really!!! wet on the crossmember holding the back of the box up
    what could this be
  2. 1vngal
    1vngal New Member
    North Tassie
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    Did you make sure you did everything up tight enough?
  3. buzurk
    buzurk Guest
    Yes im certain
  4. 1vngal
    1vngal New Member
    North Tassie
    Did you replace any gaskets necessary, if any?
  5. Burnout_bro
    Burnout_bro New Member
    HYPER VX SS/ R33 GTST
    hmmm, usual is the rear gearbol seal where the tailshaft sits, also check your allen key holes where you fill up the gearbox, pretty sure there are only 2 seals on the gearbox and next up is the rear main, degrease the box and check in a few hours or a day too see where its leaking from.
