New Head Unit
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by benno9911, Feb 1, 2010.
  1. benno9911
    benno9911 Donating Member
    Warrnambool
    03 VY S2 Exec
    i bought a new head unit and now my aerial up and down buttons are not working its all wired up right is there anything i can do to by pass the head unit
  2. nugatory
    nugatory New Member
    VS Executive S1 Station Wagon
    There is a wire that sends the signal to the aerial. On your new head unit you might've had a wire called "Power Antennae" and on Kenwood stereos this is a blue wire. It sends a signal to the BCM and then the BCM controls the Power Antennae.
    When it doesn't receive a signal, it's always in the "down" position meaning it'll always return back to down if you press the up button.
    You didn't mention it, but I'm assuming your car is a high end bcm meaning it's a Berlina, Calais or Statesman.
    I've only got an executive with a low end bcm but I upgraded the power antennae on my car to an electric one using the power antennae and power antennae module from a VP Calais to bypass changing the bcm.
    To bypass your head unit (if it's missing a power antennae wire) you hook the wire used to signal an amplifer instead. This is an external 12V+ wire.
  3. benno9911
    Warrnambool
    03 VY S2 Exec
    good guess its a Berlina yer i think the motor might have just **** it self oh well i did hook to the bule wire but i will do a few more test before i have to rip it out
  4. SweetWagon
    SweetWagon booosted
    Springwood NSW
    VS Berlina Wagon Supercharged
    Looking at my wiring diagram, there should be a yellow wire (with red trace) that goes to the bcm, i believe this needs to connect to the blue wire on the new headunit. Let me know how it goes i'm trying to suss it out now before i install mine.
    Cheers!
  5. benno9911
    Warrnambool
    03 VY S2 Exec
    yer i found fount what was worng the arial was snaped and right at the bottom
  6. Ozzie
    Ozzie JCCC Warrnambool
    Warrnambool
    Ozzie'z Supercharged VY Calais
    Why worry about the antenna and stereo if ur motors stuffed?
  7. nugatory
    nugatory New Member
    Well there's your problem, lol
  8. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    I think he means the aerial motor.
  9. Ozzie
    Warrnambool
    Would think so lol
  10. accentstencil
    Eschol Park, Sydney
    Sorry, I thought you thought he meant the car motor and why was he worrying about the stereo when the engine is stuffed.
