[LS1] New issue with ls1
themasterbutcher
Mount Isa Queensland
02 Y Series Senator Signature
Hey guys
I'm having a new problems with my darling LS1
Ok first up
It started at a miss now I only have cylinders 2,3,5 and 7
I have checked the obvious like coils leads and loom...
maybe something like Head gaskets? I can't see
4 injectors failing within 1/2 hour!
Yet I don't think I should rule them out!
Also what makes me think its a head gasket is I have a
Stealthy coolant leak! It's not going into my oil and its not on the floor
So it's making me think its leaking to to my cylinders?
Now also I haven't checked the torque of the head studs
Because I have only had maybe 30min of run time!
Do you think the heads could have loosened enough to
Allow the gaskets to **** themselves
The engine is still waiting for a tune as I did my first ls1 head and
Cam job!
It's going to hi torque soon but I would like to get it nearly finished before they
Get to it as hi torque is a 2000km drive!!! Not fun with a trailer and a stale humoured
Father lol
Just lookin for some ideas as I'm sitting in the airport miles from home
Contemplating lol
Also
Apart from the block sump rods pistons injectors and manifold everything is new!
So WTF guys lol
What's the deal
‎237/242 [email protected] Cam,
stainless 4-into-1's,
ported heads,
double row timing chain,
melling HV oil pump,
comp 1.72 ultra gold roller rockers
OTRCAI,
dual valve springs,
titanium retainers,
comp 7.4 H/D push rods,
victor reinz head gaskets,
lunati H/D LS7 lifters,
felpro gaskets,
ported throttle body
and other ****....
Regards
Simon
tyrefryer
Commodores!
i wouldnt rule anything out if you have been running such an extreme cam with no tune!
Big-Al
Banned
Aussie and proud
VY SS 5.7 M6
at a gues i'd say it's the spark plugs since you've been running it without a tune. not the best idea.
Chard
37
Australia - NSW
2000 VT s2 SS - t56
"Now also I haven't checked the torque of the head studs
Allow the gaskets to **** themselves"
The bolts are torque to yield what you say there scares me and might be your issue,, How to towards the end is sequence
Ian Johnston
Mount Gambier, SA
2015 Subaru Forester, XR6 turbo ute.
Did you use new head bolts, or the old ones? Or do you have ARP studs and nuts?? Do you know what you are doing??
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Are you testing your cooling system with a pressure tester, or just noticing coolant missing when you check it after running? You've only had it running 30 minutes so im not sure how much coolant you've lost?
