New Radiator But Temp Goes Half Way !
Rachly
Canberra, ACT
VS Supercharge Calais Series 2
Hi Guys Again
Just a quick question I want to ask.
I brought a new 3 core radiator for my VL Commodore (mine is auto).
I had a cracked head for the second time so partner re bulid my motor. So he read get a 3 core. So got 3 core but just that the temp goes half way. Im worried about that, as before it wouldn't go that high. Has coolant in it and have replaced the themostat in it. But still runs half way. I brought the radator and partner put it in the car. He says it doesn't get hot, put hands on the hoses and doesn't get hot. Only been in the past 2 weeks!
Worry or not?
NORTI
Radelaide
Wildtrak
has the system been bled properly?? If there is air in the cooling system it will read high temps, & can cause damage.
D.
bangers
45
NSW
EL FALCON XR6
mine sits on half, good for running temp as everything is nice and warm. but yes make sure the head is bled properly too.
mag
60
South OZ Adelaide
VY Series 1 Acclaim 2003
Rachly said:
Hi Guys Again
Worry or not?
Some motors can run a bit warm when just been rebuilt(tight clearences) and should get better as it's run in more.
Also when you've done 500km throw out the oil 4 sum nice clean stuff and oil filter too!!:thumbsup:
harry3
74
vl berlina wagon 6cyl
if you dont force water in until it flows out of both bleeder bolt holes the head will crack again
rb26dett
VT SS S2 A4
Did he use an aftermarket thermostat?
Get it checked by a radiator place, mine runs on half, and got it checked and it is at 85 degrees.
Standard temp gauge will move quite lot when there is only a few degerees difference.
snake_VL
VL
nothing to worry about, genuine thermostats run at about a 1/4 on the temp guage whereas the aftermarket ones (eg dayco) will run at about 1/2. just make sure the cooling system has been bled properly
adrian222
VL 5 speed now on 18's
35
nowra
VL 3.0L 5 Speed
mine runs atr half and i have just got a new radiator as well. dont be worried. only get some concern if it starts to get any hotter like 3/4
craigvk
Banned
VK 5L Calais
Rachly said:
Hi Guys Again
Worry or not?
That's normal.
JD
Donating Member
37
Deep South, SA
www.ccgm.au.tt
1.6L Turbo Holden Croooooooooooze
as long as it doesn't go any higher i wouldn't worry.
