new spark plugs now missfireing
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by kyl'svs, Dec 30, 2006.
  1. kyl'svs
    kyl'svs New Member
    Holden Commodore VS Berlina
    vs v6. was missing slighty when idling but drove ok so i changed my spark plugs now it missfires really bad when trying to rev it up quickly or accelerate from low revs .There is no craked plugs and leads tested ok. I need to fix a.s.a.p so i can go on holiday!
  2. VSIIBerlinaL67
    VSIIBerlinaL67 New Member
    VX SS M6
    what plugs are they? this happened to me when i changed my old plugs that were bosche to brand new NGK ones, started to miss exactly like your explaining, went back got new bosche plugs it was fixed.
  3. petezor
    petezor i like icecream
    VS COMMODORE
    make sure you hooked the leads up right.
  4. immortality
    Sth Auck, NZ
    check the plug gaps too
  5. kyl'svs
    kyl'svs New Member
    the old ones where bosch the new ones are ngk
  6. kezvn
    kezvn New Member
    vnexecutive wagon
    do an ohms test on your leads you might have stuffed one or two getting them off i stuffed one getting mine off because they were so bloody tight when you put them back on spray inside the end of lead with inox itwill make it easier to get them off next time cheers hope i can help also whats diference between v8 and v6 plugs if you know thanks again
  7. Fekason
    Fekason Fekason
    Penrith NSW
    Check the leads.
    I agree. It is more likely that the miss was initially caused by the leads, and it is possible that there were further damaged during the spark plug change.
  8. kopper69
    kopper69 New Member
    VRII Acclaim
    The fault is definitely either the leads or plugs. The leads can be damaged from removing them/installing them which isn't always your fault. Make sure you pull the boot of the lead to lower the chance of damage. Always, only ever do one spark plug at a time, and pull the one lead for that spark plug. This will prevent putting the leads back on in the incorrect order. Check that all leads are going to the correct place on the coil pack and spark plug. This will cause damage to your engine if they are incorrectly fitted. Also make sure the lead is sitting really tight on the spark plug, they shouldn't come off without a bit of force.
    Finally, just because you cant see a crack in the spark plugs doesn't mean they don't have a crack in them. They can crack internally if overtightened.
    Good luck, let us know the outcome.
