new springs
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by whitevrboi, Feb 26, 2008.
  1. whitevrboi
    whitevrboi Just another white vr.
    VR Executive S2
    is it possible to lower a vr by just changing the springs or do i need to do the shocks as well? also would i need a lift to do it or could i do it with a jack?
  2. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    You are better off getting shorten shocks, so that the springs don't fall out if you go over a bump or something...and just use your jack...
    Are you doing the front aswell?
  3. ashbox
    ashbox back in black
    The Car
    something black
    depends on how short your going, king lows you wont need to but anything else prob a sefe bet. and yeah just jack the car up.
  4. whitevrboi
    VR Executive S2
    yea i was gonna go 2'' lower at the front and 1.5'' at the back, could i adjsut my shock to make them shorter or would i need to buy new ones?
  5. nicko
    sa
    75 cruiser ute
    i had mine lowered 2.5inch rear and 1.5inch front and all i changed was the springs. no problems at all
  6. VRSS
    VRSS New Member
    Radelaide
    VX Clubsport R8 6-Speed
    no you dont need a hoist. you shouldnt need shortened shocks if your only lowering 2 inches. if your VR is live axel the rears are very simple just jack up one side and your spring may just come out with a little force, if it doesnt undo the bottom shocker bolt and push the diff down and pull the spring out. to put new springs just do that same thing in reverse. fronts are more difficult, undo all the top strut bolts, the 2 bolts that connect the hub to the strut and pull the strut out. compress the spring and undo top strut bolt, remove spring and reinstall in reverse process.. good luck
  7. whitevrboi
    VR Executive S2
    Cheers for all your help guys i'll see how i go on the weekend and post how i went
