new starter motor issue
MRVX6
VX berlina ecotec/ vy ss ute
hey i just put in a new / remanufactured starter motor from sprint auto when i turned the car on it sounds like the gear on the starter motor gets cought on the fly wheel on the way out!! do i take it back or is there something i didnt do right any help would be great thanks
Dayvo
Because i can
64
South East,Victoria
VE SV6 Series 2
When you took out the old one did you notice if there was any shims between the starter motor and the engine ? If there was you need to use them when fitting the new one to retain the correct clearance
MRVX6
I didnt notice anything, i rang sprint back up and they said something about my flexplate/ flywheel could be worn?
Cameron P
Quakers Hill, NSW
REDHOT VX SS
is it a squelling noise? but only when you start your car when its cold?!?!? thats your flywheel
MRVX6
nope does it every time i start the car, it sounds like when your cars on and you go to turn the key again thats what it sounds like!!
pablo
Donating member
Was a 1997 vt v6 wagon
Perhaps the pinion sprag clutch is faulty? ..Could have been not detected when starter was recond, and put back in service. Bloody hard to detect out of vehicle.
oska
vx custom 600RR
loosen the bolts and then do them both up by until they are hand tight as best you can, make sure it seats flush
then tighten them up
MRVX6
i think it may be faulty too but if i take it back they need to send it away to get it tested :mad:.
i will give it ago tomorrow oska!
MRVX6
Problem solved faulty starter :boxing:
