newly installed 3 stage, with probs... help
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by yyg998vsute, Dec 4, 2006.
  1. yyg998vsute
    yyg998vsute New Member
    Hurstville NSW
    1998 Blue VS ute 5spd
    Hey all
    If you have been checking out the forums recently , I have had the 3 Stage all put in
    Air Con now works, all sweet
    but, considering it is manual, my fuel consumption per 100ks just says zero
    and What would be the best way to adjust the flow cal
    Looking at another forum , it vary's to the size of your wheels
    I have 19's so if there is any solution to using the same someone elses flowcal
    and the litres per 100kms it would be greatly appriciated
  2. struggo
    struggo Member
    Old Sydney Town
    2016 VFII SSV Redline + 2013 FG MKII G6ET
  3. immortality
    Sth Auck, NZ
    i'd say something isn't hooked up quiet right. even if the calibration number was wrong you would still get a reading for ltrs/100km. do you get an instant fuel reading at all or distance travelled?
  4. yyg998vsute
    Hurstville NSW
    Thanks struggo, good stuff
    but...
    It doesnt come up with anything at all
    just 0.00L per 100
    0.00 litres used
    and the other one, cant remember
    i might see if I hook up another one if anything changes
    bare in mind
    I used the Berlina/Calais loom to install it, and it still hooked up the to the original BCM and VS manual ECU
  5. immortality
    Sth Auck, NZ
    it's not hooked up right as your not getting any readings at all. i'm sure there are some threads about changing to the L3 clusters so i'm sure somebody knows what you need to do/change
  6. Fekason
    Fekason Fekason
    Penrith NSW
    Extra Wire?
    Did you connect the extra wire required for the fuel flow? This wire is additional to those than come with the fourth connector?
  7. stocky
    stocky New Member
    by stage 3 do you mean the level 3 dash? the wire that goes across to the ECU is what sends the instantaneous fuel usage data. if its not connected properly it will just read 0
  8. yyg998vsute
    Hurstville NSW
    Thats got to be it then
    anyone got a diagram on how too,
    i havent got any wire running custom to the ecu
    Thanks guys
  9. shaggerz
    shaggerz New Member
    Victoria Point, Brisbane
    2004 VY2 SV8 A4
