wannaeatyourbrains
- Sep 24, 2019
- 591
- 544
- 93
- Age
- 52
- Location
- Mecca
- VZ Executive
You can just get a long bit of hose, suck a little fuel into the end of it, hold the throttle body open and and blow it into the plenum. That will tell you if it starts when there is a fuel supply.
To check fuel supply, yeah get someone to turn the key to nearly turning over for you. Crouch at the back and just listen for the pump working in the tank.
You can also do that or turn it over a bit. Then disconnect the battery if you are scared, and depress the Schrader valve on the fuel rail. Black cap on the fuel line at the back of the motor. If fuel squirts out, you got fuel pressure, and fuel to the injectors. No dribble, no joy. There is your issue.
Every time I thought an issue was the ECU, it never was. I have pulled a dozen off wrecks, and they are all good, no matter how burned or mouldy. You can get them tested before you buy a new one if you want the confidence.
There is a Fu Manchu thread on here about the low fuel no start issue. Replacing the timing chains often sets this off. When it happened to me it was a PIM issue, needed Tech 2 to make it communicate again.
Maybe double check you reconnected all the plugs, back of the plenum, throttle body, MAF, camshaft sensors and solenoids. Heat of the moment and all.
Check your camshaft sensor wire is not cracked too, especially where it loops on Bank 2. You might have to peel back the tape a bit. They get brittle in the heat. I had that problem once myself, and have seen it since. Running like a dog till it wouldn't run any more is the classic symptom, and it could have been the problem all along.
