No air-con pressure in 2002 vx commodore
stilli1988
2002 VX Commodore Executive S2
Hi,
there seems to be no air flow from the air-conditioner when it is on recycle but on fresh air there is air flow.
Just wondering if there is a cabin air filter that needs replacing?
If not, what could be the cause of the problem?
Thanks in advance, Steven
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
No cabin filter.
Are you saying that there is no airflow in recycle mode with the fan on?
accentstencil
71
I'm not sure but I can only assume a flap isn't opening or closing as it should. Sorry I can't be more specific.
Immortality
Staff member
Sth Auck, NZ
As above, the air system is controlled by a number of vacuum controlled solenoids. Can you hear a sucking sound when on re-circ mode?
The vacuum control module is located above the kick panel in the passenger foot well right next to the center console area, pull out that panel and look for loose/blocked/damaged vacuum hoses.
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
Check the vacuum hoses on the back of the air directional flow selector on the dash.
Also, the selector it's self may be faulty. There are seals behind the vacuum hose manifold of the selector,
so vacuum doesn't leak from one selection, (e.g. face to feet) to another.
