No dash/console lights
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Stuo666, Feb 20, 2012.
  1. Stuo666
    Stuo666 New Member
    Christchurch,NZ
    VS Executive SW,VN Executive,HQ Belmont
    My VS Commodore has no dash or console lights working. I have pulled the dash apart and tested all the bulbs and they work fine. Obviously ive check all fuses and they are fine. Maybe a bad or broken earth somewhere? I bought the car like this about a month ago and thought it would be a easy fix,previous owner did a auto to manual coversion if that makes any difference. Any ideas anyone?
  2. magnetvh
    magnetvh New Member
    BROOKDALE W.A
    VH SL/E 381pack
    Is the dimmer wheel/switch all the way up.
    Also check ur headlight switch
  3. Stuo666
    Stuo666 New Member
    Christchurch,NZ
    Just had a play with dimmer switch and that doesnt seem to help, maybe theres a bad connection to the switch, i will investigate in that area.
    Someones already had dash apart as a few plastic tabs broken :(
