No Ground to Starter Relay
DrewBoyer
Australia
VY V6
Hey all, car wont start as the ground pin (-Ve) to power the relay's coil is not pulling to ground hard enough.
When Relay -Ve is connected to Batt -Ve or Ground, relay operates as intended. When relay is connected to Starter Relay -Ve port, relay does not fire.
12v is seen at Relay -Ve & +Ve when key is turned to start position, however the -Ve is the problem here not the+Ve.
I really need a wiring diagram of some sort. Any suggestions?
Much appreciated!
the_boozer
no more VK
51
Shitsville Morwell
hilux
the pcm switches the relay earth
