No indicators or hazard switch indicating
40
adelaide
vr berlina
Hey guys here's a good one,
I have a vt commodore i have checked all the fuses and they seem to be fine. It is missing the flasher relay in the cabin so I replaced it with the power windows relay which works and still no indicators. It was also missing the fog or Parker lamp replay I am cant remember under the bonnet and I did the same thing I switched it with a non essential relay that had nothing to do with the indicators and still nothing. So is there a common problem that stops the indicators from working.
mpower
Are you sure you are reading what relay is what correctly, you can't just have missing flasher relays....
40
adelaide
vr berlina
I will have to check the switch, I double checked the missing relay and it definitely does not have a flasher relay also
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
You can't just replace the flasher relay with a standard 4 pin relay, it wont work. It has to be the relay that makes the indicators work (flash on and off). It has to be the proper 3 pin flasher relay.
There is NO other relay in the indicator/hazard circuit. Just the flasher relay, the Hazard warning fuse and the Turn signal fuse.
40
adelaide
vr berlina
I'm a dumbass :( but thanks for the info I will check the hazard and get the appropriate relays from a wrecker or super cheap if they have them.
st3r3otyp3
Donating Member
VX HSV VX SS
+1 Hazard switch it happened to my VRSS when I had it.
jughead1
Central Coast
VX Commodore Executive
Supercheap sell the correct indicator relay for around $38.
On ebay they are around $27.
JG
Sikkinixx
Ford Traitor :(
04 VZ Wagon
Working on that basis, I have a VZ wagon I've just repaired. My indicators work perfectly, but I have no hazard or lock lights. I've noticed the relay for hazard lights (GMB) is missing and unsure what the relay should look like .Is it just another flasher relay ?
Nut Kracker
Donating Member
64
Echuca Vic.
VT SS 304ci (195i)
The VZ models have a hazards fuse number F7 (as opposed to the turn signal fuse F12).
Maybe that has blown.
I can't see a hazard relay in the wiring diagram.
