skippy73
- Feb 5, 2013
- 67
- 5
- 8
- Location
- townsville
- vt 5.0 ltr
holden 304 no oil pressure. no oil getting up top to the heads, packed full of vasoline, then started it. checked tappets couldnt see any oil.
pulled oil pump off. You could see the cogs inside the oil pump had been turning an some of the vasoline was gone but no oil, cleaned the pump out put it back on , filled oil filter with oil. Took the oil sender out
put a little hose in there fill it with oil. started car. no oil to the top end. started the car while oil filter was released to see if it would pump oil out nothing comes out just what was in the filter. Check the oil pick up in the sump Put on a new gasket. still nothing...Any ideas
