vombil
I thought I'd post again with narrowed down problem. I found the connection from loom to fan motor absolutely cooked and melted... amazingly the fan works perfectly still!
BUT! I have found now that I only have 0.02V to the power supply at the fan motor and 0.04 with the car running. I've tried 3 HVAC units. I've swapped out relays and inspected fuses. In the process I now have scored a 'ABS OFF' dummy light which I didn't have before. I have swapped BCM and key with another than is compatible as confirmed by Holden.
Any takers? PLEASE
Any takers? PLEASE
