the pink one in that plug is the important one its the trigger to turn on the ecu hit it with 12v and see if it goes should goto pins E9 and A4 on the ecu the plugs are marked with the numbers and letters
im goin to the wreckers 2morro and getting the under dash loom this will go to the gear t/bar as well
i almost forgot about that
does any one know if the ECU is ok to run an external bosch 44 or will this pump need a direct ign +.
i all so can fit the vs pump in tank (just fits through the toy tank ) but the one i have here is burnt on
the white plastic were the - terminal is so im goin with the external unit
you can run any pump you want off the ecu it just needs a relay like the stock setup you cant run anything directly off the ecu .im guessing its a carby lux and doesnt have stock intank pump
this is the pump
with the in tank pump working i was thinking (not sure) of it feeding a surg tank and this pump goin to the engine as toyota tank has no baffle and well hoped that would do the trick
