if you need to fit a bigger return the safest way is pull the fuel sender out and drill the hole in that and weld in fitting or pipe and then refit to take dont drill the tank if you dont have to.copper will be fine for fuel dont know how legal it will be but
thanks m8 im confident again
this is the connector that plug's in just above the ecu it has the following colors wires
K.B / PINK.BLACK .1
BROWN.WHITE .2
BLUE .3
VIOLET. WHITE .4
BLACK.WHITE .5
WHITE.BLACK .6
BROWN.WHITE . 7
RED.BLACK .8
I WENT TO THE WRECKERS TO DAY AND GOT THE PLUG TO HARD TO GET THE ENTIRE LOOM
i think this is how it goes
K.B / PINK.BLACK .1 maybe ign A4
BROWN.WHITE .2 not sure check engine lamp F5
BLUE .3 power economy switch F12
VIOLET. WHITE .4 speedometer C5
BLACK.WHITE .5 not sure
WHITE.BLACK .6 Diagnosis connector B3
BROWN.WHITE . 7 not sure brake fail lamp B9
RED.BLACK .8 constant power B8 A8 20amp fuse or Diagnosis connector A3
it is not clear to me how to tell the brown and white wires apart as there is 2 of them but i can trace them down to the ecu HOPE
