No refill oil showing on the dipstick
Discussion in 'VE Holden Commodore (2006 - 2013)' started by VEdriver59, Oct 21, 2016.
  1. VEdriver59
    VEdriver59 Member
    VE, 09 of 2008, Omega, Auto, 3.6 Litre, 6 Cylinder
    CP 09/08, Built 09/08, Holden, Commodore, VE MY09 Omega, Sedan standard auto.
    I replaced the oil filter and tightened it up. Drained the oil into a pan, replaced the plug and then pulled out the oil refill cap and started refilling. Went to do a progress refill check and nothing on the dip stick.
    checked it again several times during refill and still no show.
    continued to put what I thought was about the right amount in and in put the refill cap over the hole, not reinstalled and left it.
    1 hour later no change, 2 hours later about 5-6 mm showing on the dipstick.
    3 hours later still no more than 5-6mm so I started it up and shut it down as quick as I could.
    cleaned the dipstick each time before checking the fill level
    20 minutes after startup shutdown nothing on the dipstick
    checked for oil on the floor under the car but nothing.
    never had this problem before with any car
    What do I do now?
    thanks to all.
  2. redvxr8clubby
    redvxr8clubby Active Member
    Sunshine Coast QLD
    VX Clubsport R8 & VE SS
    How much oil have you put in it? The V6 takes about 6.7 litres. If you've only put 5 litres or less in, you'll need more.
  3. gossie
    gossie Well-Known Member
    Gold Coast.
    VE International 3.6L
    Have you used the correct oil?
  4. VEdriver59
    VEdriver59 Member
    Thanks, I have not put that much in but I put about4 litres in. would that not be enough to show on the dipstick?
    I use Mobil Super 1000 which I've used quite a few times before without problems, thanks
  5. strgas
    strgas GRA = REAL HP
    recommend you down load the Castrol oil app so you can check oil grade and quantity require for just about any engine ,
    Castrol Australia - NetLube
    I use this app most days to check which oils and how much to refill
  6. VEdriver59
    VEdriver59 Member
    Righto; I put a few more litres in and now its way over full. Dont know what happened there. The level is about half inch over the top.
    How do i get the excess out? Thanks
  7. VEdriver59
    VEdriver59 Member
    Thanks, I'll have a look at that, sounds handy
  8. Taz_SSV
    Taz_SSV Member
    VE SSV UTE
    Just had a quick look it calls for 7.6 - 8.3L for my L98. Surely it doesn't take that much oil???
  9. lmoengnr
    lmoengnr Well-Known Member
    Sunbury Vic.
    MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
    It sure does! I have an L77 and a LS3 and both take 7.6 litres for a complete fill.
  10. Taz_SSV
    Taz_SSV Member
    VE SSV UTE
    I just bought it and had the full blown works done by a mechanic but from now on I will service it. Had it for 2000kms so still got a little too go. What do you do? Buy a 5L and 2 x 1L.
  11. redvxr8clubby
    Sunshine Coast QLD
    Buy 2 x 5 Litre, you'll have about 2.5l left - next service buy 5l and you'll be about right, possible you'll need that little bit more though.
  12. stooge
    stooge Well-Known Member
    wa
    VF SSV
    its always best to find out the oil/coolant capacity of the engine before doing an oil/coolant change.
    when I do my ssv it takes about 7.6 ltr for a change, when I refill it I put 7 ltrs in and let it settle then I will top up the other ><600ml to the full line.
    to get the oil out take the sump plug out and let some oil out and put the plug back in then retest the dipstick until you have the right level
  13. gossie
    Gold Coast.
    The books that come with your car tell you exactly the capacity of the sump and the correct oil to use.......Did you read your books???????????
  14. Taz_SSV
    Taz_SSV Member
    VE SSV UTE
    No book was supplied with my car. I have tried sourcing another one however as you can imagine if I get one that means another car is missing it's books. And wreckers tend not to have books as insurance companies usually destroy them when a vehicle is written off.
  15. greenacc
    greenacc Searching for the billion
    VE Berlina
    Yeah buy 2 of the 5 litre bottles or a 10L or 20L if you really want to. I just wait until i see the 5 Litres at a good price and grab 2. Then when its getting close to your next service time look out for another sale... One of the everyday Synthetic varieties would be much safer to use. Most of the big auto stores now have little computers at the oil rack which will help you select the right oils to use in your car with just a few clicks of make and model etc
    Mobil Super 1000 is a Mineral oil and not what is recommended for your Alloytec engine. I wouldn't use it, certainly wouldn't leave it in there for the full 15000 k service interval. If you do that you will have serious issues with sludge very quickly.
    Have a read of all the threads in the VZ and VE sections on engine sludge. It's not pretty.
  16. stooge
    wa
    VF SSV
    a lot of the oil manufacturers websites also have the oil find/selector option too.
    if the op really wants mobil oil use this page, select vehicle model/type etc and it will tell you the capacity and mobil oil to use.
    Mobil Australia - NetLube
  17. gossie
    Gold Coast.
    I just noticed the OP put the totally incorrect oil into his VE.
    Please OP empty that oil out and replace it with high quality 5w-30 oil. It is very important for the life of that complex engine.
    I notice for whatever reason you purchased your VE without the books that do tell you the correct oil to use, it even tells you 5w-30 on the oil filler cap so why would you have not even taken notice of that information?
  18. mitchy_
    mitchy_ Member
    QLD
    Senator SV08
    definitely the best way, the 1L bottles are too expensive. fortunately my 3 cars require the same oil and total up to 19.9L, so 4 bottles when they are on special sorts me out.
  19. commodore665
    commodore665 expat Saffa
    New Zealand via Cape Town
    2005 SV6 & Alfa Romeo 156 V6
    I agree , Mobil 1000 , is not the correct oil to use , drain it out and replace with Dexos approved 5W 30 oil , and it'll save you in the long run
  20. cwill624
    cwill624 New Member
    2008 Sv6 60th Anniversary Ute
    Definitely go synthetic, better engine life and the car runs a lot nicer + better fuel economy and less heat
    Synthetic is not even that expensive, i got 7l of Nulon full synthetic for mine for $65 including a filter
    For that price its worth changing oil every 7500 km's!!
