No spark???
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by sebstenator, May 7, 2008.
  1. sebstenator
    sebstenator Burn
    VN SS 5.0
    my car has been really wierd lately.
    before when it started it started but ran like a pig and couldnt rev high.
    after we fixed the firing order but it still seemed like it was out.
    then it said the 3rd cylinder was being fired first.
    so i switched the leads around so the first cylinder was being fired first.
    checked it but the first cylinder wasnt firing first anymore.
    then noticed i lost spark in the 4th cylinder and now i dont have any spark in any of them???
    i have no idea whats up.
    iv got new leads sparks dizzy cap rotor button and coil.
    anyone have a clue wots going on??
    how do i test and set all the timing proply?
  2. wildss
    wildss Member
    s.e melb
    vnss
    start by checking you have all the leads on right i posted a pic for you.
    did you have your dizzy out at all?
    check your coil to see if it works and ignition module by using one that you know works
  3. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
  4. sebstenator
    sebstenator Burn
    VN SS 5.0
    iv got spark now and i hooked evrything up and the dizzy hasnt been taken out.
    but how come it shows the firing order of 12784563? so 1st cyl goes to 1 2nd goes to 2, 3rd goes to 7 4th cyl goes to 8 and so on??
    cos it looks different on the pic but ill giv that a go cos the way i did it isnt starting so fingers crossed.
  5. sebstenator
    sebstenator Burn
    VN SS 5.0
    nope no luck even with that diagram.
    i dno if its got to do wit my battery being **** but yeh i have no clue wot the **** is goin on
  6. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    If it is turning over slowly, it probably won't start, it will need a good 80% battery capacity to fire.
    Does yours have the twin contact rotor button?
  7. sebstenator
    sebstenator Burn
    VN SS 5.0
    im not sure.
    but iv made all the timing correct and it sounds like its just about to start but it doesnt.
    any ideas wot the problem could be?
  8. vn calais manual
    vn calais manual New Member
    vn calais, vs clubsport #137
    check fuel pressure.
