noise from belt?
younglion
2002 VY SS Ute 5.7
hi when the car is in park i can hear a squeaking noise coming from the belt area at the front of the engines and when i accelerate it gets louder as i go faster is this the belt or something else?
Bluewildangel
35
Vt II supercharged
well if you have any silicone spray lying around go and spray the belt it usually cures squeeks
Trevor 062
St Clair
2012 VE S2 SSV REDLINE & 07 VZ ACCLAIM WAGON
I had the same deal...mechanic changed the belt... fixed now..
Dayvo
Because i can
South East,Victoria
VE SV6 Series 2
Could also be the altenator, water pump or one of the other pulleys
younglion
2002 VY SS Ute 5.7
so i get some silicone spray and just spray on the belt?
WAGON MAN
Gas Sleeper
North Coast , NSW
VX S2 Berlina Wagon with Phreddied bits.
Yes spray it on both sides of the belt and also on the pulleys.
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
Just spray it on with engine running. If the noise doesn't disappear then it's one of the pulley bearings, waterpump, alternator or A/C compressor bearings.
younglion
2002 VY SS Ute 5.7
just sprayed it on with it running got rid of most of the noise, thnks guys, do i need to spray the fan belt as well???or just the belts on the pullys on the front of the block
accentstencil
68
Eschol Park, Sydney
There is only 1 belt, it has nothing to do with the fan, people just call it that. It is call a serpentine belt or drive belt. You should spray the belt as well.
