HSV 671
- Jan 3, 2013
- 213
- 0
- 0
- Location
- qld
- 04 VY CLUBSPORT MM6
Hi all.
I have a 04 Clubsport T56 and latley i have noticed the box is very Noisey when warmed up. Not you usual Thrust/Spigot noise (yes that was there before too).
I can only assume the Noise seems to be from bearing/s inside, because after you press the clutch in and select 1st the Thrust Noise disapears, But the other (bearing type noise is still present)
i can also hear it from outside the vehicle when eng temp is normal. I thought it may have been the Fans and A/C but it still doing it without those either being on. Some 1500km ago i droppped the old
auto Spec oil and replaced with the penrite Syn 70-75 Specified by Tremec/Penrite. Also when going slow and pressing clutch in, there is a clunk type noise as well as a slight whine. If you go fast enough to change, it doesnt appear.
Is this a symptom of bearings too? Clutch seems fine ( a bit hard to select 1st sometimes), Changes smoothly, no leaks. It has 200,125km.
I dont give i a hard time.
Can someone confirm what this noise's are and will it lockup or some crazy sh** when im driving it?
Cheers.
Cheers.
