Noisey when using clutch
Gothevu
Off the chain
Townsville QLD
VU S2 Ute - 5 sp manual
Most morning when i go to work my clutch sqweels just in 1st and reverse and goes away after driving for twenty or so minute. The clutch has only done 50,000kms any ideas.
veclubby
35
South Perth, WA
2007 VE Clubsport
hmmmm, dunno mine doesn't make any noise so im guessing it cant be a good sign.
got plenty of clutch fluid? only thing i can think of..lol
catchya
ryan
Gothevu
Off the chain
Townsville QLD
its got plenty of fluid and even blead the clutch still does it
Jesterarts
Your freedom ends where mine begins
2010 Nissan X-Trail ST-L
Does it squeel as ur releasing the clutch into gear?
Could be a clutch slip...
I got a slip in my clutch... pretty annoying really... wears the clutch quicker too....
Damn dual mass flywheels!
Gothevu
Off the chain
Townsville QLD
It squeels as you put the clutch in to put it in gear, i booked it in on wednesy to get at hope it won't cost to much
WinterVX
N/A
Yep, another one of Holdens bright ideas.....too bad they aint that strong either
seem to wear down very quick!!
You guys get a bit of driveline backlash aswel?
Gothevu
Off the chain
Townsville QLD
they should have solid flywheels standard like the vn- vr,
if he does have anything to do with clutch and that might pay a bit more for a solid flywheel from extreme clutch.
Gothevu
Off the chain
Townsville QLD
Found out it was throw out bearring and piolet bearring to,$155 for and bout 3-4 hrs labour
WinterVX
N/A
nah, more talking about hitting the accelerator hard then letting go a few times
over and getting a 'clang' from the tail shaft.
