Noisy engine at cold start
Member 1
45
Australia
VX
When I start the engine, there is this noise that start a bit louder and as the engine gets to normal operational temperature it becomes much less noisy.
Drove the car for some 15 km and i almost did not hear that noise at all?
What is causing this issue?
lowandslow
NSW
V2 III Monaro
Does it sound like a tick or tap that increases and decreases with revs?
lowandslow
NSW
V2 III Monaro
Perhaps a lazy lifter? What oil are you running?
krusing
Melbourne, Bayside
Could be a Water Pump, Alternator, Pulleys, that quieten down when they get to Temperature.
Check the hardware with a mechanics stethoscope.
krusing
Melbourne, Bayside
Thanks krusing. I just don't have one!
You can use it for all types of diagnosis,
Pulleys, Hardware on the engine [water pump], Lifter noise, noisy inlet/exhaust valve, the list is endless.
I had an unusual noise on my Super6,
and purchased one, and found 2 pulleys were the cause, and then realised the Supercharger Snout and Blower Bearings were also noisy,
I would not of found that out without it,
And now it runs so quiet when krusing [cruising].
Where the link I provided is a much cheaper than what I paid,
But looks exactly the same.
All the doctors in the world couldn't be wrong :D
https://www.ebay.com.au/i/323926144...MIoOutoL6H5QIVUj5gCh2G9gWIEAQYAyABEgKV-_D_BwE
Trevor loves holden.
vs commodore
Can you pin point the area? Most high k's engines tick when cold, carbon build up or sludge or wax or varnish deposits causing sticky/noisy lifters, they do have additives to help clean / break down the carbon that you can add to oil, and they say using 98 octane has more cleaning agent added to also help break down carbon on valves.
I give my pulleys a spray with wd40 if the noise fades you found the crook bearing. Might not be the correct way but it works for me.
