normal readings for vs?
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
1995 VS Commodore v6 ecotec
yay finaly all the gauges are in, so i dont have to anoy you with questions on how to install them!
however i do want to know, what the normal temps and pressures are
water- 1/4 - 1/2 the dash gauge (every one knows that)
oil pressure in BAR: ?
oil temp: ?
just so i can see if shes runnin fine or not
thanks in advance, cheers
cander24
NSW South Coast
VZ GTO. VS LS1.
1 PSI converts to 0.07 BAR
At idle a vs v6 should have an oil pressure of 62 PSI and at any engine speed over approximately 2000rpm this increases to 66 PSI. So, using these figures you should have a pressure reading of 4.34 BAR and 4.62 BAR respectively. Im not sure about the oil temp sorry. Hope that helps.
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
brilliant mate! thats right were shes sitting!
thanks heaps for that - im guessing that as the oil warms up the oil pressure is lower, when the oil is hot om the tepm gauge the vs idols at 3 bar
your a champion, thanks for your help!
now i just gotta get the oil temps!
VSIIBerlinaL67
35
VX SS M6
ive got 5psi oil pressure at idle lol. its getting rebuilt atm.
Immortality
Staff member
Sth Auck, NZ
i'm interested to see what oil temps your getting. mine takes ages but eventually gets upto 210degrees F (about 100degrees C) i can get it hotter by really giving the loud pedal a workout. i've also noticed once it is upto temp variations in watertemp don't seem to effect the oil temp much (if anything) although i do run a 82degree thermostat so my engine runs cooler then normal.
my VN with (ecotec oil pressure spring) idles at about 60+psi when upto temp
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
in the last 2 days ive noticed that mine gets up to and stays arround 100c (goes over but not under) i have noticed that the gauge is a lil dicky tho and under heavy breaking the temp rockets up, the needle bounces when the indicator is on and when the sterio is up loud or under a heavy bass load it bounces arround lots, but the normal temp is between 100-120c, again im prety heavy footed, actualy i think my foot is made of lead but most of the time its between 100 and 120, ive noticed the same with the water temp, has little or no effect on oil temp and my oil pressure is arround 4bar under normal conditions, but when the oil is hotter (around 100c+) it sits around 3 (some times 2) bar, when im off the throttle
sounds prety similar to yours!
