not a smooth clean startup ?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by muzza, Jul 12, 2008.
  1. muzza
    muzza New Member
    gladstone
    vx berlina
    hi guys got a vs v6 series 2 got about 230 000km every now and then when i turn the key to start its not a clean even idle straight away like it used to b for a about 2 - 3 seconds its a rough idle just as u turn the key kinda like not enough fuel is in the engine straight away i service it regulary but the fuel injectors r original as is the fuel pump car seems to drive normal any ideas ? thanks
  2. CANYONERO
    CANYONERO Likes Cheese...
    Country SA
    V8 6spd wif MOMO leavaa.
    you cant expect a car with nearly a quarter of a million kays to run the same as it "used to" my VS V6 did a similar thing, ran like a dream apart from that.
  3. AttaBoy
    AttaBoy WTF?!?!
    VS Acclaim V6
    Yeah they are getting really old... but they are tough as nuts (Mine is) just make sure you have clean injectors so try give them a clean. Also check for any error codes.
  4. Cursed CX8
    Cursed CX8 Banned
    Walking distance to FG meets
    VY Adventra
    injectors
    fuel pressure regulator
    fuel filter
    air filter
    DFI - leads - packs - plugs
    could be any of them, id say leaking injector seals, or fuel pressure reg
