Not enough power :(
kcpwns
Kicker - Livin' Loud :)
Shepparton
VY V6 Equipe
haha damn...
all good though I'll just invest in a multimeter for now...
I have a bit of stuff to buy..damn 1st year wages are a killer
one_and_only2004
Turbo L98 FTW
Regional NSW Australia
Z Series Thunder Utility - Turbo
Well if you're not going to use it much don't go buying something overly expensive. In my experience the cheaper meters do the same thing but just have a lower rating ie. Don't go checking the power coming out of the power point with your $20 dick smith special.
kcpwns
Shepparton
VY V6 Equipe
lol I work with electricians most of the time...they have some funny stories of people doing that..
or using those cheapo volt light tester pens and people getting zapped by them...
ahh commonsense is lacking in some people ...
sweefu
VY Berlina V6 / R31 Skyline
wrx884
WA's ASR Rep
39
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
ur car has its own volt meter already via the trip computer so no need 4 a seperate gauge unless u want it 4 wank factor?, Tho still always best 2 check with a multimeter 2 make sure its accurate and u can use it 2 test that regulator of urs.
kcpwns
Shepparton
VY V6 Equipe
I like the look of the blue stinger gauge...mite get one...although I dunnno where I'd stick it
Haha you will have to let me know how the cheap one goes
kcpwns
Shepparton
VY V6 Equipe
Sorry what? Mine is just a vy equipe does it still have a voltmeter on the computer?
kcpwns
Shepparton
VY V6 Equipe
D'oh...
I didn't know that...Im guessin its in the mode function thingo when you start the car up?
wrx884
WA's ASR Rep
39
sure is :) On urs hold down mode and set and turn ur ignition on, if u keep holding u can start the car and it'll display while the cars running, at 1st u'll hear a beep and then a serial number will pop up that'll tell u that ur in the hidden trip menu, press mode 2 scroll through until u find ur volt readings.
as said tho its still handy 2 buy a multimeter 2 check and make sure the readings r the same.
