V6 are faster, lol.Why would the OP downgrade?
That'll go well. Got a roadblaster in mine, very happy with it - had a larger cam though (probably a little too big).
you're getting the trans rebuilt too aren't you? Get some upgrades fitted when they overhaul it, i believe some upgrade parts are already fitted from factory when the trans has a V8 in front of it.I hope it goes better than well haha I'm sure it will, the tuner said the roadblaster is a good converter I'm sure I will be happy with it.
Be sure to do all the lifters, timing chain set, valve springs, pushrods etc when the cam goes in
You might want to consider a 4L65e then. Other members would be able to say for sure though whether the 60e can be built strong enough to handle boost.Yeah I want it built to handle some boost later down the track.
When you buy the cam buy the rods to match the cam. Mace Engineering will set you up with a cam and HD push rods. Do you have memcal? Mace will sell you a chip as well matched to the cam. Then you can dyno it once you get all te upgrades done. With the Mace package it will be close, tune wise.
