Not firing on rear passenger side cylinder.6 cyl.
greigbec
shepparton
VZ Calais
I have just found out my vz calais isnt firing on the rear passenger side cylinder. I have swapped plugs with no change. Then swapped coils no change. Even tried rear o2 sensors. Anybody have some ideas of what may be causing this
99notout
VZ Equip Wagon
If the injector is cactus the ECU will turn of the coil for that cylinder. Check the codes, and check the injector. Hope that helps.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Not firing will either be fuel or spark. You have eliminated spark, so check fuel. Swap the injector to another cylinder and see if the miss moves with it.
VK SL 3800
VK SL 5spd
I had a VE alloytec with a miss, the problem was the pins in the plug to an injector had opened up. Closing the pins fixed it.
greigbec
shepparton
VZ Calais
I have a mate checking the injectors tomorrow. Will let you know how he goes. Thanks for all the suggestions
greigbec
shepparton
VZ Calais
All fixed. Number 6 injector Was 95% blocked. Fuel filter was blocked. Cleaned all injectors changed filter and blew out fuel lines. Runs like a dream now. Thanks for the advice really appreciate it
