Not sure
Discussion in 'Car Audio' started by COMMY VP 666, Jan 14, 2009.
  1. COMMY VP 666
    COMMY VP 666 COMMY VP V6
    COMMODORE VP
    i am having one amp on subwoofer, another amp on rear speakers
    on my cd player i have relised it was a
    RCA spot
    REAR OUTPUT OR SUBWOOFER OUTPUT
    AND
    FRONT OUTPUT
    what does the front output do?
    thanks in advance, just need to make sure so i dont have to buy a splitter
  2. Zeussy
    Zeussy SSM11K
    Central Coast
    Gen-F Clubsport, Rodeo 2.8 TD 4x4
    the same as the rest of them, they will supply a feed for amplifiers, the front is usually used in the front speakers, my stereo has 6 RCA sockets, 3 red 3 white, all up, --- a seperate set one for subs, one set for fronts and one set for rears, just make sure the 'fade' is set to zero, like front to rear, or it might not sound right,
    correct me if im wrong people..
    hope that helps.
  3. COMMY VP 666
    COMMODORE VP
    so the front output RCA"S can be used for rear speakers?
    lol just really gotta make sure
  4. hakhawk
  5. StoneX
    StoneX New Member
    Hastings
    VE Calais-V 6.0L
    Yes, the front RCAs can be used for the rear speakers, it just means that if you have front speakers running from your head unit, you won't be able to fade front or back. You'll have to set the gains on the speaker amp to match the front speaker volume.
    Can I ask why you're amplifying your rear speakers but not your front speakers? Stereos always sound better with good front speakers amplified and then the rears off the head unit or amplified. Your front speakers should produce the most sound... Having rears louder than your fronts is like going to a concert and facing away from the band :p
