bmxbogan
- Mar 9, 2010
- 22
- 0
- 0
- Location
- sunshine coast
- vz sv6
i have a 06 sv6 and i put pacmaker headers on a while ago and about a week after i got a check power train error finaly got around to buy a obd plug and got the error codes and they were two o2 sensor low voltage codes did a bit of searching around and realised that the cat pipes that i got with the headers had the 02 plugs welded in in front of the cats so i have 2 on the headers and two more beore the cats...
this is where i need the advise... will the error be because the sensors are busted or because they are before the cat and are ment to be after it.. also they are quite dirty if i clean them will this make it go away or wll i have to get new ones or will i have to get the sensors relocated?.. i can clear the codes with my tool to check if it fixed but dose anyone have any ideas and also if i replace them will they just brake again because they r in the wrong spot
