O2 sensor readings
Discussion in 'VF Holden Commodore (2013 - 2017)' started by Wayne001, Aug 9, 2018.
  1. Wayne001
    Wayne001 Member
    Meadow springs
    Vf calais
    Hi all i was driving around today while running the torque pro app and was reading the voltage on my o2 sensors on my vf 6ltr . The bank 1 was fluctuating between .8 and .1 fairly quickly whilst bank 2 would fluctuate a lot slower and at times sat at .7 or .8 this was whilst cruising at about 1700 rpm . When putting my foot down the both read .9 and when coasting up to the lights both read 0 . Is my bank 2 sensor just getting lazy ? Thanks .
  2. wamboin23
    wamboin23 Donating Member w/ Boost
    Wamboin, NSW
    VS Calais - Cooled L67 + T56 | VR Acclaim V6
    Are you sure you weren't looking at bank 2, sensor 2?
    A post cat o2 sensor won't really move much, except under acceleration and deceleration.
  3. Wayne001
    Wayne001 Member
    Meadow springs
    Vf calais
    Nah definitely bank 1 on both sensors .
  4. Wayne001
    Wayne001 Member
    Meadow springs
    Vf calais
    Any one ?
  5. 07GTS
    07GTS Well-Known Member
    Australia
    VEGTS BLOWN E85
    could be a sensor getting tired they should both be moving over and under 450mv for closed loop, swap the sensors and if it changes sides then get a new sensor
  6. Wayne001
    Wayne001 Member
    Meadow springs
    Vf calais
    Good suggestion, what is the easiest way to get to the connectors ?
  7. 07GTS
    Australia
    VEGTS BLOWN E85
    not sure i have aftermarket pipes on mine so have some room to get to the plugs still a bit of a pain tho usually from underneath works with mine
  8. Wayne001
    Wayne001 Member
    Meadow springs
    Vf calais
    Thanks , i changed my exhaust manifolds a while back and just unscrewed and wound them up and put the back in the new manifolds. Tried getting to the conectors but was near impossible so i gave up on that idea .
