hsv ss
- Apr 4, 2010
- 19
- 10
- 3
- hsv enhanced vs ss 5.0 a4
I have a 2007 VE sv6 auto which I’m converting to 6 speed manual
It has 6 wire precat o2 sensors on the existing exhaust and loom
The new loom I’m fitting from a SV6 manual ute has 4 wire precat o2 sensor plugs the same as post cat plug on my existing loom
Does anyone know if I can just modify the loom with the 4 wires from the new loom joining the corresponding colours on the existing 6 wire sensors or whether I need to fit 4 wire sensors on the precat side of the exhaust?
I have the ecu from the SV6 manual ute included in the conversion kit.
I’m determined to make it work one way or another and I’ll try it with removable plugs so I can test whether it will work with the 4 wire loom attached to the 6 wire sensors
I’m thinking the loom is possibly from a series 2 VE ute? Or possibly the Utes have different o2 sensors?
The only other difference between the looms is the starter solenoid wire is a plug on the existing loom and the new loom has a lug to be bolted onto the starter motor solenoid.
Any help will be appreciated
