O2 Sensors how many
miedwards
VS II Wagon 3.8
I have a 97 VS S2, and I am trying to work out if I have 2 O2 sensors, as there looks like there is one on each exhaust Manifold, (at the bottom,)
One points towards the engin( pasenger side) and the other points sideways away drivers side, so are these my O2 Sensors, ( it apears that there is 2 wires going into each sensor.
angelo.vs
Autobot
40
Honda Accord Euro Luxury
I got told by a mechanic that there are 2 sensors.
Bax
Projecting
40
QLD
Nothing
There would be two, one for each cylinder bank.
SaGe
VS II S-PAK Manual
2 wires to each sensor? it should be 4 wires to each sensor 4 a 97 SII
VZ Berlina
they definatly have 2 sensors. 4 wires sounds about right. my mums got my car so i cant go out and check
J
Joes_meat
Guest
It's either 3 or 4 wire.
One of the wires is a 12v positive - this is the heater wire.
Then a ground for the heater.
And another ground for the data line. (shared with heater ground on 3-wire O2's)
Then the data line. Which should range from 0-1Volt.
I can't remember the colours mind you...
NeilB
66
VR Caprice
2 Sensors for a V6 1 sensor for the V8
SaGe
VS II S-PAK Manual
the o2 sensors come in 2 wire aswell but im pretty sure thats 4 earlier models
J
Joes_meat
Guest
The VN's had a pair of non-heated O2 sensors. Probably VP and possibly VR's too.
