DJ_Cosmic_Fire
smarter not harder
- Apr 26, 2011
- 502
- 11
- 18
- Location
- South East Queensland
- Website
- www.house-mixes.com
- VP S-Pack Oct '91 - VT SrsII Wagon
This is one of my vehicles being a '91 SrsI S-Pack VP HSV optioned by first owner, I'm the 2nd owner so not many around like mine in the 8 years I've owned it. I've only ever seen one other & that's me living in the 3 Eastern States. If you know me then you know what it's capable of due to the mods I have applied. I don't fry tyres as it's just stupid IMO, I get 6.9 per 100 & run different tunes to suit various conditions. It was originally owned by a Uni professor so I doubt he was doing fully sick burnouts in it lol.
I originally got it to drive down to Victoria from the Northern Beaches in Sydney, I bumped into a mate in 2007 who said his old man had an old VP with plenty of added options (like an 80 litre fuel tank) that he hadn't used since 2002. I dropped by checked it out & drove off happy with it, as there were log books plus a giant folder full of receipts from work done on it since he'd purchased it brand new from Suttons in Arncliffe. It had 145k on the ODO, still absolutely immaculate SS interior, no rust, very straight plus perfectly kept paint etc. There is no indication that the currently installed Buick will not keep running full-time, very tough high torque motor. Eitherway I've built a new fully worked performance Buick motor, which I will put in on my break. There were only 1000 of these VP variants made (stock) & at 1.3 tonnes, the power to weight ratio is the best out of VN VP VR Buicks.
__
Suspension :- SL Kings Springs all round with matching KYB short stop rear Shocks & front Strut inserts. SuperPro Bushes fitted right throughout the entire vehicle, New front Nolathane complete lower arms (new lower ball joints included) New OE Radius Rods (Z-Caster Bars) , KMAC Adjustable strut top bearings, Fulcrum Strut Brace, WASP Balljoint style front link Pins, 30mm KMAC front swaybar, 22mm Whiteline Adjustable rear swaybar, Pedders Adjustable Panhard Rod.
Brakes :- OE V8 All Round New Brembo OE Disc Rotors Front & Rear, Bendix Ultimate Front & Rear Pads, Overhauled V8 brake booster, New 1" master cylinder, New OE flex lines all round. I replace the brake fuild each year & service all the calipers when required.
Wheels & Tyres :- HSV VP Senator Rims, fully skimmed to OE specs, New wheel bearings & new Bridgestone Supercats (will get better tyres soon, but they do the job pretty well for street use)
Powersteering :- Brand New OE Powersteering rack (including rack ends, corrugated boots & tie rod ends) plus new "Blue" Powersteering pump with a Magnafine inline particle filter on the Powersteering return line.
Exhaust System :- Full Custom Made Stainless Steel Sports System, Mandrel Bends throughout with Twin 200 cell hi-flow cats & Hurricane Extractors.
Differential :- Fully Rebuilt tight centre, OE Borg Warner Converted to 3.45 over the stock OE BW 3.08 LSD, Installed New/Reconditioned Drive shaft.
Naturally Aspirated Air Intake :- VS S/C OTR, K&N Panel Air Filter, 3 hole airbox mod allows all 3 high pressure air zones to be utilized efficiently. I run tough corrugated tubing to both sides of the base areas of radiator which inclusive of the OTR gives maximum air flow.
Transmission :- TH700 Complete Performance rebuild with a Transtec up-spec'd kit, including an extra wide carbonite 2-4 band & "The Beast" reaction shell, plus 3-4 Z-Pac clutch plates, New Hi-Stall 2650 RPM TLC, Stage II shift kit, Corvette servo, 0.500 tv boost valve & sleeve, Transco Hi-RPM Rev Kit & new trans filter kit plus a few other accumulator related enhancements. Deep Trans alloy polished sump pan with drain plug, B&M 14,400 BTU Trans supercooler, plus a Magnafine inline particle filter on the Trans return line.
Engine :- Currently installed - Rockers are 1.9:1 HRRR, Crow pushrods, Crow Lifters, bored out Inlet Manifold & new Inlet Manifold gasket set, plus replaced all the cooling hoses, heater tap & heater hoses plus front & rear Kilkenny Castings inlet manifold bungs, New Thermostat housing & Hi Flow Thermostat, renewed water pump, New Radiator, New High Output Alternator (also the big "3" upgrade) , New idler pulley/bracket & New Gates serpentine belt, swapped out throttle body for a top quality bored out & polished 70mm unit, I port matched & polished a spare manifold adapter elbow then contoured the bellmouth for maximum flow to the last 2 cylinders plus allowing 90% more air into the manifold, cleaned MAP, MAT & IAC sensors, cleaned PCV valve, replaced fuel regulator plus new fuel sender hoses, replaced DFI with a New unit (coil packs), New Bosche OE 4 hole Spray pattern injectors, High quality DriveForce Ultra-Max 8.5mm Silicone Ignition Leads along with properly gapped (I do 1.4mm) NGK Spark Plugs :- (BPR6EFS-15's), renewed the brake booster vacuum hose to intake elbow, thoroughly cleaned air intake induction pipe & corrugated boots, (I throughly flush out the cooling system then refill each year) , New VP OEM Oil filter adaptor & gasket plus Ecotec pressure relief spring & valve (= 75psi Oil Pressure!), New Powerbond Harmonic Balancer & New CAS. (Oil is changed by me every 3 months using Penrite 20w - 60 Extra 10 & Liqui-moly anti-friction additive & I use K&N hi-flow oil filters).
New Engine On Stand :- I've built a Brand New hi performance 3800 Buick S/C ready motor with bowl ported heads, E.V.L valve & guide set, Hypatec pistons, stage 2 Crow Cam, bee hive springs, Crow push rods & lifters, CS6VP Crow Timing set, New Timing chain tensioner, 1.7:1 YT rockers, cometic head gaskets, fully ported inlet manifold, 9.6 n/a up from 8.5 compression to allow 10 - 12 pound boost from which ever FI I choose - be it a complete Twin Turbo set up or just keep it neat with the Roots Supercharged Eaton M62, which was originally standard equipment for the 3800 in the US.
I have a reco'd & ported Top Mount Eaton M62 & I have created a custom 25mm insulator to match. For the Twin Turbo set up fuel delivery is vital & I have completely assembled 3Ltr Surge with dual 044's running -8An braided S/S lines, from boot to bay into custom fuel rails/rising rate sard regulator. The S/S braided line goes back to the fuel tank to complete the cycle. The new 255 Walbro internal hi-volume fuel pump I will install regardless of which path I choose. This will include a quality custom a2a intercooler set up, 2 Bar Map sensor plus tune & 6 x 833cc Deka injectors for when I go FI (will be live Dyno Delco tuning after installing FI though) . I have this new performance V6 3800 now properly mated up to another new TH700R & a 3k Hi-Stall TLC (other TH700R & Hi-Stall TLC are fine - Great spares!) . I'm about 75% there now as the pics show, & I'll break it in N/A with the Custom Bench N/A tune on my next break.
I am rebuilding the old 3800 original S-Pack engine from the ground up with similar specs, all the good bits but a larger cam, even stronger bottom end & more quality time spent on the head porting
__
