Oil Filter
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by benno9911, Mar 31, 2010.
  1. benno9911
    benno9911 Donating Member
    Warrnambool
    03 VY S2 Exec
    My car dose kinder not want to part with its old as oil filter and suggestions please
  2. V8Silverfox
    V8Silverfox New Member
    North Shore, Auckland, NZ
    MY04 VZ SS A4
    Are you using a filter wrench? If not, (and you are sure that you have the right replacement) lightly hammer a screwdriver (phillips) through the side if the old filter to use as a wrench. (It will leak dirty oil as well, over you if you're right underneath the filter!)
  3. benno9911
    Warrnambool
    03 VY S2 Exec
    never thought of that thanks, and i have taken a few of outer cars and i have never need a filter wrench well i just went to autobarn and said i need oil/filter fuel filter and air filter so if its all wrong look out incoming brick
  4. benno9911
    Warrnambool
    03 VY S2 Exec
    Thanks so much worked like a treat it was on there bloddy tight
  5. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    Only tighten the new oil filter hand tight.Dont use any tools to tighten it.
  6. benno9911
    Warrnambool
    03 VY S2 Exec
    all done took it for a drive and its load better
